Topic: Virtual DJ 2021 keeps crashing - Page: 1
Hi I’m using and Acer Aspire 3 with Windows 10 and a pioneer DDJ SB3 controller . On Friday I updated to VDJ2021 and it keeps crashing and restating. I’m not online and not doing live broadcasts I am only mixing a few tracks . Today I had to restart my laptop because it kept crashing every minute or so . I have used VDJ for about 7 years now and never had any problems. Can you please help
geposted Sun 21 Jun 20 @ 12:11 pm
Have you got the new stems EQ stuff turned on? FYI there have been other VDJ updates since Friday.
geposted Sun 21 Jun 20 @ 12:15 pm
UPDATE
I have discovered that VDJ 2021 crashes when I’m skipping through a track while it’s playing
geposted Sun 21 Jun 20 @ 12:34 pm
No new stems . Nothing has changed since using VDJ 2020 . I’ll try downloading new update thanks
geposted Sun 21 Jun 20 @ 12:36 pm
I have just reinstalled VDJ 2021 from the website and same thing is happening when I’m skipping through a track it just closes down and reopens
geposted Sun 21 Jun 20 @ 12:41 pm
Yes something has changed. VDJ 2021 added a big new feature, and I'm asking if you have that enabled.
How are you "skipping through" the track?
geposted Sun 21 Jun 20 @ 1:45 pm
OK, it's nice if the graphics on your song show instantly, but it's not a necessity. It won't affect your ability to play the tracks.
Splashing out for a new graphics card or gaming laptop will improve the new stem analysis, but that's all. The functionality will be the same and the sound will be the same.
check :Add music to video with built-in 900+ background music for videos 🎶
geposted Mon 22 Jun 20 @ 8:48 am
Yes tits enabled . I’m skipping through the track using the cursor on laptop and the track I’m skipping through is the one that’s cues up not the track playing
geposted Fri 26 Jun 20 @ 10:07 am
You said earlier that you're not online. What do you mean by that?
Is your computer connected to a wifi signal or via a cable to your router? If it is, then when it crashes and restarts, Atomix should be getting crash reports.
If they are, then they will be able to see what's causing the crashes.
geposted Fri 26 Jun 20 @ 10:17 am
There are indeed some crash reports. The development team will likely look into them
geposted Fri 26 Jun 20 @ 10:43 am
Virtual dj keep crashing and recovering in my computer, never had this issue until VDJ 2021downloaded...it is frustrating
geposted Sun 28 Jun 20 @ 5:53 pm
I'll confirm too. Version 2021 when playing music suddenly closes the software and reopens losing all selected settings. frustrating crash. :(
geposted Sun 28 Jun 20 @ 9:27 pm
kelreyPRO InfinityMember since 2014
I have all the problems with a DDJ-Sx2 the update needs a serious revision and that they give us back VDJ 2020 while it is solved
geposted Mon 29 Jun 20 @ 2:20 am
What problems? Be specific. Also give details of your setup. Mac, PC, operating system and so on.
VDJ 2020 is still available. It never went away.
geposted Mon 29 Jun 20 @ 9:37 am
My equipment is i7 of 7a. Generation 2.70 GHz to 2.90 GHz, 16 Gb of Memory, Intel HD Graphics 620 Card, plus Nvidia Geforce 940MX, Operating System Windows 10 version 2004
You have the link where I find the 2020 build ¿?
geposted Mon 29 Jun 20 @ 5:06 pm
LIMOLPRO InfinityMember since 2003
geposted Mon 29 Jun 20 @ 5:25 pm
geposted Mon 29 Jun 20 @ 6:49 pm
You still haven't speficied what your problems were...
Well hopefully if you were online and VDJ crashed, Atomix will have a report.
geposted Tue 30 Jun 20 @ 8:10 am
Dear Groovindj
- Playback closures
- activating hot cues restarts VDJ
- Using the knobs for effects restarts VDJ
- White lighting in the Jog area jumps throughout the playback (Clarify Not the jump indicating end of track)
- The audio quality of the DDJ-Sx2 has decreased ... not linked to Stems performance (Stems 2021 is excellent update)
I will continue using VDJ 2020 I know that these problems will be solved soon !!
Regards !!
geposted Wed 01 Jul 20 @ 7:30 pm
@kelrey
I have noticed from your Account stats that you have been using a combination of DDJ-SX2 ASIO and some "wasapi-Dual Stereo"
Can you try to use just the Pioneer ASIO in your Audio setup and see if you still have crashes ?
Also, see in your Windows Audio settings and set your computer's built in sound card as default playback and Microphone/Recording device instead of the Pioneer (if was set so)
geposted Thu 02 Jul 20 @ 5:17 pm
36%
