Exactly the same problem for me: Migration to M3 and I can only use stems in reduced quality. From "On-Demand" I get this error message. And I can't empty this computer and set it up again because it is heavily used.
Who can help? 😨 csrutil disable and enable make no difference.
geposted Sun 21 Apr 24 @ 10:31 pm
Same issue here, migrated from M1max to M2max, and I use STEMS all the time....
geposted Thu 30 May 24 @ 6:51 pm
Pato Selekta wrote :
migrated
If you read the earlier posts in the thread, it's stated that you should not use the migration tool.
geposted Thu 30 May 24 @ 7:25 pm
This is how I fixed it:
1. Old Mac make back on external drive using Time Machine
2. New Mac (with updated IOS) I configured it as a new machine, once in the OS, restore using migration tool selecting Time Machine backup.
3. VDJ now processes STEMS
geposted Sun 02 Jun 24 @ 9:40 pm
Hi, do you think it might work that once I set up as a new Mac, instead of transferring with time machine I transfer the data with migration assistent?
Thank you very much
Thank you very much
geposted Tue 16 Jul 24 @ 4:17 am
If VDJ hasn't found a solution to this since 2022, despite my recent purchase of a lifetime license, I am afraid I'll have to move on to another DJ platform.
I migrated my Mac, and everything else works like a charm (I also have Rekordbox, Djay Pro, and Serato installed, and they all work just fine). Fresh install without migrating my info is definitely a no-go - I use my Mac not only for Virtual DJ.
geposted Fri 02 Jan 26 @ 7:33 pm
