HOLA
Aquilino les dejo un video
ENGLISH .Hi guys I need help with the skin 2025 VANCED GT , when I look for a song the king suffer modification ,please check the video below ,I would love to save this issue
Thank you in advance
DjMiamisalsa wrote :
HOLA
for the new skin Vanced Gt .al buscar canciones en la barra ,se modifica o varia el skin ayuden a deshabilitar esa accion .Gracias
geposted Wed 05 Mar 25 @ 3:54 pm
HOLA
geposted Wed 05 Mar 25 @ 4:06 pm
HOLA
Disable the “Browser Zoom (Auto)” option in the main drop-down menu.
And also you should not leave something enabled if you don't know how it works.
geposted Thu 06 Mar 25 @ 9:56 pm
thank you ,can u send me an screan foto how to do it .and this happen just with the new ADVANTED GT SKIN .ALL OTHERS SKING WORKS GOOD
geposted Sat 08 Mar 25 @ 9:33 pm
Vanced GT is working fine too, you activated the automatic browser option, and that's what it does.
That you activate things and leave them like that even when you don't know what they do is not my fault, it's not the skin's fault.
I think I should make the main menu button even bigger so you can find it?
geposted Sat 08 Mar 25 @ 10:24 pm
yes bigger Iyu a right
thank you
thank you
geposted Sun 09 Mar 25 @ 11:44 pm
