I have a numark platinum fx controller. If you know much about it you know it doesn't have a lot of knobs besides the eq high low and mid and maybe a couple more but I have Turnado vst and if you know about this plugin it uses lots of knobs. Right now I'm using the eq knobs on deck 1 and 2 to control it. High eq knob controls slot 1 on turnado deck 1. Ok I have the Turnado also in deck 2. Whenever I turn the eq high knob on deck 1. Slots 1 and two change on both decks. I don't like that I rather have eq high deck 1 control slot 1 on Deck 1 and eq high on deck 2 control slot 1 on the plugin. Is it possible to get this done? Im having issues figuring it out. What's the best way I can map this out? What's the best mapping that I can use?
geposted Wed 05 Aug 26 @ 3:36 am
What script are you using?
geposted Wed 05 Aug 26 @ 3:59 am
I dont know much about scripts. I just went in the mapping settings and made some adjustments Thought I just said the script. I don't know.
geposted Wed 05 Aug 26 @ 4:02 am
you're using a script... unless you're using midi to vst...
geposted Wed 05 Aug 26 @ 4:04 am
I using default just made a few edits. For numark and virtual DJ.
geposted Wed 05 Aug 26 @ 4:05 am
give me the script you have for eq_high
geposted Wed 05 Aug 26 @ 4:07 am
Oh ok I'm not in front of my computer. Do u know a script I can use that will work for this?
geposted Wed 05 Aug 26 @ 4:11 am
I do, but I'm asking for what you have now to give you the right answer.
geposted Wed 05 Aug 26 @ 4:15 am
I think it's eq high deck 1 1 which controls the spots on turnado slot 1. Something similar to that. Once I get back home I can give the exact one for each mid high and low.
geposted Wed 05 Aug 26 @ 4:24 am
Effect active 1 1.
geposted Wed 05 Aug 26 @ 4:26 am
just you and me in this thread, you don't have to go quoting replies
EQ_HIGH effect_slider 1 1
EQ_MID effect_slider 1 2
EQ_LOW effect_slider 1 3
geposted Wed 05 Aug 26 @ 4:41 am
Ok thanks I'm gonna try it out later.
geposted Wed 05 Aug 26 @ 4:05 pm
Does slider 1 represent deck 1? When I map deck 2 I use slider 2?
geposted Wed 05 Aug 26 @ 5:45 pm
no,
decks are specified by default at the definition level, as you can see EQ_HIGH is a key name assigned to deck 1 and deck 2 control under a single mapping.
the parameters used in this case are
effect_slider
INT (fx slot number)
INT (fx slider number)
geposted Wed 05 Aug 26 @ 5:54 pm
You understand what I'm trying to do right? I wanna use eq knob high on deck a to control slot 1 in turnado and on deck b eq high knob to control slot 1. I'm gonna have Turnado on both decks.
geposted Wed 05 Aug 26 @ 9:12 pm
This my mapping deck 2 effect_slider 3 Eq low
geposted Fri 07 Aug 26 @ 4:17 am
That moves the eq low on both sides though. I need a script for each individual knob. Deck 1 and 2. If that makes sense.
geposted Fri 07 Aug 26 @ 4:19 am
no you don't.
geposted Fri 07 Aug 26 @ 4:20 am
Ok I go to settings then controllers and in key: is EQ_HIGH action is deck 2 effect_slider. It works on deck 2 but how do I set the EQ_high on deck 1 to work for another effect for example flanger on deck 1? is this possible?
geposted Fri 07 Aug 26 @ 4:43 am
I don't have a lot of knobs on this controller to work different effects so I've decided to map the eq knobs to them.
geposted Fri 07 Aug 26 @ 4:46 am
