It's eq_high & effect_slider 1. I found it I had to remove deck 1. Thanks for the help Loco dog.
geposted Fri 07 Aug 26 @ 5:03 am
It works but it messes with my eq when I turn it. I need a controller with extra knobs.
geposted Fri 07 Aug 26 @ 5:06 am
action_deck 1 ? deck 1 effect_slider 1 1 : deck 2 effect_slider 1 1 this is it.
geposted Fri 07 Aug 26 @ 5:22 am
the query or deck specifiers are not needed,
that the query works tells you a deck is already specified at the definition level like I said.
geposted Fri 07 Aug 26 @ 3:16 pm
