Hi had this problem a while ago and it seemed fine after the updates
but again it has returned
when draging an MP3 on to a deck to play it takes for ever to fully load the track
i have defraged and done all the other things like virtual memory ect
i am running 1gig memory
2000 cpu
80 gig hard drive
2000 cpu
80 gig hard drive
geposted Wed 17 May 06 @ 4:19 pm
do the songs look like they have been already anaylized? did you try the speedload tweak?
geposted Wed 17 May 06 @ 5:23 pm
Hi yes al songs have been pre analysed
what is the speedload twaek please?
thanks
thanks
geposted Wed 17 May 06 @ 6:06 pm
Hi thanks did that but it was already at 0
thanks for your help
geposted Wed 17 May 06 @ 6:30 pm
oops yes your right default is 0 so change it to a 1 ... i forgot i did my home comp already too
geposted Wed 17 May 06 @ 6:35 pm
what it change actually?
thx
thx
geposted Wed 17 May 06 @ 9:52 pm
changing it from 0 to 1 makes the mp3's load faster but leaves less room for error for video files this isnt a problem if your video's all run fine
geposted Wed 17 May 06 @ 10:31 pm
As it comes with the time, i think you have to defragmentate your hard disc
geposted Thu 18 May 06 @ 6:42 pm
I did Defrag!if you read my original post!
yep changed it to 1 seams much better thanks for your help
geposted Fri 19 May 06 @ 11:42 am
no problem rossy glad to help
geposted Sun 21 May 06 @ 3:50 pm
