Topic: Error Message - Page: 1
Sup all, I was using VDJ this moring, took a nap and when use it again to record some remixes and then tried to download songs from my HD. I keep getting that lovely Fatal Crash message with the smiley face. I ty to recover from it and nothing. I get an error message of R6025. Any ideas?
MS
geposted Sat 25 Nov 06 @ 5:09 pm
You tried restarting your Pc? and see if it happens again
Yes I also reinstalled VDJ and nothing yet...:(
MS
got xp?
Yes I do and I am using VDJ 3.4 still.
MS
go to startmenu
programs
acessories
system tools
pick system restore
choose a date about 2 days ago
and this will restore the settings of your system to this time , i think this could solve this for you
another thing to try would be to upgrade to v4
I will try this Sky. Thanks. BTW congrads on the VIP status. Also I don't care much for V4 due to the Effects usage. I perfer V3.4 Effects engine alot better.
MS
goodluck , thanks :)
i kinda agree with the fx thing but the new one has its merits aslo :)
I'm back and still doing the same thing. Anyother suggestions?
MS
Delete your registry entries for VDj then reinstall
Start----Run "type in the box" "Regedit"
Since your using only 3.4 the entries should be under
HKEY_LOCAL_MACHINE / Software
find the whole VirtualDj folder right click and delete it you can also check for entries in the HKEY_CURRENT_USER / Software
I will give it a shot.
MS
cool
becareful mistakes will crash ur pc bigtime
Tried it and still the same thing. :(
MS
The Support Team should have a list of error codes, so they can get it up for you quickly or know right away what it is causing it
Thanks guys.
MS
PC + lake + strong arm = problem sorted... for the meantime :D
Jokes, but i wonder why it gives a cheeky smiley face??
Lol , Good point maybe it should be changed to an aggrevated face
Well it seems that it's a Windows Xp error not a VirtualDj error, just google windows xp error r6025
dont suppose you have aol software on your pc , that aparently can cause it
try to dissable some of the programs that start during the boot
start -> run-> type msconfig and go to the startupfolder,dissable all,then go to services and check hide all microsoft services, disssable all services that you don´t need,apply and reebot your computer...most of the microsoft errors has to do with startup processes
I did a googel on the error and it says that it can be caused by some java based applications & other visual bacis c++ shit sfuff
63%
