Forum: Old versions
Topic: Virtual Dj for MacBook Pro - Page: 1
Hi Greetings.
First of all, sorry my english, it's really bad.
The point is: I have "HERCULES MK2" and "VIRTUAL DJ-CONSOLE" in my pc, i bought that last year, but now i got a MacBook Pro and i want to mix im my mac, where i can go to download the VIRTUAL DJ-CONSOLE for mac?
I've allready the driver of HERCULES MK2, but Virtual Dj-Console not yet.
Can you guys help me?
TKS. :D
geposted Thu 16 Oct 08 @ 3:20 pm
xonorPRO InfinityMember since 2005
Hello neighbor.
You can install it from the cd that comes with the MK2.
Anyway, if you are thinking to use it in mac, you can update to the PRO version having a discount because you have the Hercules MK2.
Hello vizinho.
Você pode instalá-lo do Cd que vem com o MK2. Em todo o caso, se
você estiver pensando para o usar no mac, você pode atualizar à versão PRO tendo um disconto porque você tem o Hercules MK2.
Você pode traduzir pressionar F4 em seu keyoard. Tente-o.
Eu não sei portugues, mas eu datilografei em inglês
Boa noite.
geposted Thu 16 Oct 08 @ 5:10 pm
i can't install...
the setup comes in .exe, and mac dont support that extension... :s or i'm doing something wrong??...
geposted Thu 16 Oct 08 @ 6:10 pm
spinnaJPRO InfinityMember since 2004
As u have version with the old hercules series, i'm sorry u have to upgrade to pro in order to have access to the mac version.
Hope to see u as a pro user soon;)
geposted Thu 16 Oct 08 @ 7:39 pm
LCB667PRO InfinityMember since 2006
Hola una pregunta. Por años fui usuario de Pc y desde hace un año mas o menos e querido cambiar totalmente a mac. Pero resulta que el virtualdj pierde la base de datos. bueno encuentra lo que busco, pero despues de una set corto, lo encuentra pero al querer cargar me marca ERROR. Y el resultado es que tengo en mis tres mac que usar el Win Xp. Claro con el Boot Camp. Pero pues no es el caso, quiero usar mi virtual en mac. (Tengo Una Imac 2.4 de 20', una Mac Book Pro 17' 2.16 y Una Mac Book 2.0..., 2 Xponent y 1 Hercules Rmx Les agradeseria Mucho me ayudaran a resolver este problemita. Gracias
geposted Sun 19 Oct 08 @ 3:03 pm
Hi pls use the spanish forum or write english in here. Thanks;)
Are u saying about sound error using ur rmx via bootcamp?
geposted Sun 19 Oct 08 @ 3:20 pm
Translation:Hello, one question: for years I was an PC user and for almost a year i wanted to switch completly to MAC, but it happens that VD losees the database, it finds what i am looking for, but after a short set, it finds it , but when I am trying to laod it, I get an ERROR.
The result is I have 3 MAC's running XP on Boot camp, but I want to use Virtual in MAC . (I Have Imac 2.4 de 20', una Mac Book Pro 17' 2.16 y Una Mac Book 2.0..., 2 Xponent y 1 Hercules Rmx)
Thanks for the Help.
geposted Mon 27 Oct 08 @ 12:25 pm
Hi mauvelez.. thanks for the translation;)
@LCB667..
Try running VDJ on MAC OSX..n u should be fine.
About the song that have error, what format are those. U need to add new codec if it is not mp3 etc.
If u using leopard, just set permission to read n write. There a lot in the forum regarding abt this. It been covered numerous time.
Regards;)
geposted Mon 27 Oct 08 @ 12:30 pm
Hola amigo.
Este es el foro en inglés de apple mac.
Yo te voy a responder en español, pero debes escribir en inglés.
Actualiza a la última versión de VDJ, es la 5.2.1
Pásate por AQUI.
Puede que se arregle tu problema.
Have a nice day.
geposted Mon 27 Oct 08 @ 4:04 pm
Is there a trial version for MAC? if yes, where can I download it from?
geposted Mon 27 Oct 08 @ 6:24 pm
I use Trakktor Scratch with Audio 8DJ, will VDJ work with native-instruments Audio 8 DJ on a MacBook Pro?
geposted Mon 27 Oct 08 @ 6:25 pm
Sorry, there's no trial version for Mac.
geposted Mon 27 Oct 08 @ 6:27 pm
HiTowerPRO InfinityMember since 2007
VDJ will work with the Audio 8, but not with timecode.
geposted Tue 28 Oct 08 @ 1:06 am
hello everybody
I cant setup the sound on my mac y have a hercules rmx can somebody help me
geposted Wed 29 Oct 08 @ 5:28 pm
leonardoaguayo wrote :
hello everybody
Look HERE.
But don't do the options that says "Inputs: TIMECODES" leave it with NONE.
Good luck.
geposted Wed 29 Oct 08 @ 8:14 pm
Hello again
I did left use the right setting and it worked well before but i do not know what's wrong i use the same settings than before and it doesn't work
geposted Wed 29 Oct 08 @ 8:50 pm
Hi leonardoarguayo..
Can u define more of ur problem.. It be better to give us more insight of it.. Thanks;)
geposted Thu 30 Oct 08 @ 12:04 pm
Help!!!! I just installed Virtual DJ on my MacBook Pro. When trying to do videos, nothing appears, the audo is playing but on the video screen is just black. Any suggestions?
Thanks,
Greg
geposted Thu 30 Oct 08 @ 6:52 pm
What format is the video that u playing gchrisfolo?
Does it happen all the time or to certain files?
Regards;)
geposted Fri 31 Oct 08 @ 2:16 pm
It is .mov files that were converted using QuickTimeMPEG2 in cinematize pro. I can get generic videos to work. Is there something I need to add?
Thanks,
Greg
geposted Fri 31 Oct 08 @ 4:22 pm
63%
