What is the "proper" way to search with 6.0.2?
Here is what I do and not sure if its the "correct" way since it sometimes produces a crash...
Type in song in search, double click on song below to load in a deck then click on the search box to clear the field.
Is this the correct way to search and clear the search box? If not, what is the correct way?
geposted Sat 12 Sep 09 @ 11:31 pm
I would say so, that's how I do it anyway
geposted Sun 13 Sep 09 @ 4:00 am
i just type the search, drag and drop then onto another search, don't think i've ever had a "search crash"
geposted Sun 13 Sep 09 @ 7:04 am
same here never had a search crash i just click on search box then drag and drop track into player or use load button on dac 3 not had a crash in months in fact the last crash was using the trial version before i bought version 6 pro
geposted Sun 13 Sep 09 @ 7:09 am
How do you clear the search field? Do you backspace through, click on the space below the search box then back into the search box, click on a favorite folder, etc ?
I tend to like to keep my search box empty so I can see the songs listed in the selected favorite folder but in the past sometimes when I click on the search box to clear it is when the crash occurs.
I DID hose my laptop and start over with a clean install of XP SP3, 6.0.2 and a fresh new database (took 36 hours to analyze files!) and I did not have any issues on a 3 hour gig. I was expecting the search crash but it didn't happen. I even had Trend Micro auto-protecting! I will, once again, put the system through its paces next Saturday, or earlier if I'm lucky.
geposted Sun 13 Sep 09 @ 4:41 pm
i do both, either double click to clear or just back space if it is a small text search
geposted Sun 13 Sep 09 @ 5:50 pm
that's what I used to do in 5.2.1. Wait...isn't that what you're still using or have you done the same type searching with v6?
geposted Sun 13 Sep 09 @ 9:46 pm
got it on desktop, still trying to pick up the confidence to put it onto the gig lappy, never had a problem with the search it was the random shutdowns that was the problem i had.
geposted Mon 14 Sep 09 @ 4:29 am
Hey JayMSY,
try this one.
Create a Keyboard shortcut with and write exact search '' & search into the action field.
'' = 2x semicolon ;-)
Now, when you press your "SEARCH" Keybord Button, VDJ jumps into the searchbar and delete all the content.
But it works only when you are not in the searchbar!
If you are still in the seachbar, it doesn't work ;-) and you must use backspace to delete the unwanted letters.
I use this function always for serach and load then with the load button on my controller, the needed track into the deck.
But you can also use your mouse(doubleklick) or create another keyboard shortcut for Deckload.
I hope it helps!
Haui
try this one.
I hope it helps!
Haui
geposted Mon 14 Sep 09 @ 5:40 am
Haui means 2 times accent, not semicolon ;-)
Greets, Heiko
geposted Mon 14 Sep 09 @ 6:05 am
Are any of you seeing a delay in search returns while typing in the text?
geposted Mon 14 Sep 09 @ 6:59 am
fine for me.
geposted Mon 14 Sep 09 @ 7:22 am
No lag for me with the shuttle system (internal drives)
Laptop does lag quite a bit, but nothing to hinder the operation.
Still using 5.02 on both systems.
geposted Mon 14 Sep 09 @ 11:21 am
Greets, Heiko
Greets, Heiko
I am lost on both of this? Right now I have a keyboard shortcut for Ctrl+S which will place the cursor in the search box. What does the keyboard shortcut above do and what IS the exact action of the shortcut?
geposted Tue 15 Sep 09 @ 2:09 am
The shortcut will first clear the search field and the jums to it.
Greets, Heiko
Greets, Heiko
geposted Tue 15 Sep 09 @ 8:56 am
Hey i just wanted to ask what happen to seeing the video image, of the video stream. It was available in version 6.01 pro. It was helpful in determining if it was the actual video or just a video montage of the artist and album cover as well as being helpful in determining if was the actual video or something that was wrong all together. If the net search search developers can reimplementing the video image covers in net search i would appreciate it.
geposted Sat 26 Sep 09 @ 12:56 am
i normally just type in search box then scroll with my rmx and load with rmx.if im using just laptop ill drag and drop song.got crash once using double click not sur if it was from d click or just the search bar.after the cras i was goin throgh my folders rather than search but seems fine in 6.1
geposted Sat 26 Sep 09 @ 4:35 am
@macavelli, there are other threads going on for netsearch, if you can't see what your after post your own thread, you'll get a better response that way.
geposted Sat 26 Sep 09 @ 5:17 am
search '' & search is a great trick how to clear the search field and then jumps to it, but is is working only with 6.02 and older. Not in 6.03! In VDJ 6.03 is shortcut entered in the search field as a first letter. What now? Can you help me? I need this functionality like before....
geposted Fri 13 Nov 09 @ 11:24 pm
Use a key in combination with the <CTRL> key - because these combinations will befiltered internal by VDJ.
Greets, Heiko
Greets, Heiko
geposted Sat 14 Nov 09 @ 5:01 am
