Hmm, ctrl + key - two keys together. Any other VDJscript trick (macro etc...) how get back this function with only one key like before?
geposted Sat 14 Nov 09 @ 9:56 am
I have a search issue that drives me crazy, please let me know if anyone else has this issue.
I have a playlist open and for instance I sort by bpm , I load songs scroll down etc everything is fine then I get a request search for a song load , play , wonderful. Then I click back on my playlist and I have to resort and scroll back to where I was on my playlist all over again, this may sound trivial but it drives me nuts, Is there any way around this?
geposted Sat 14 Nov 09 @ 10:34 am
In VDJ 5 was reset option with search (on picture).
But now in VDJ 6 is something like search_reset verb in VDJscript missing. Can you add this back?
For resetting you just have to put an 'empty' value to the search field. Use this for example:
This clears the search field and sets focus to it. When using it with <CTRL> key (<STRG> Key) you can also clear the field when focus is set to it.
Greets, Heiko
Quote :
search '' & search
Greets, Heiko
geposted Sat 14 Nov 09 @ 3:06 pm
search '' & search - Yes, i know this trick, as i wrote above (5 posts back). But now it is working only with CTRL key together. Without CTRL is shortcut entered in the search field as a first letter of searched string. In all older VDJ it was working great without any CTRL. This is my "problem". I want press only one key, like in the older versions of VDJ. That is why i have my "idea" with search_reset verb as an easy way how to get this (one key) search+reset function back.
geposted Sat 14 Nov 09 @ 7:38 pm
Hey super7877
I have the same CRAZY Problem also and i'm using VDJ 5.2.1 and it drives me NUTs when your buzy, it's a problem from HELL!!!!!.
Also program crahes all the time if you type in ozone in the search box yes ozone or zz, I reported this on a post and got a reply to upgrade to 6.3 and that it was fixed?
any body else knows about this problems?
Is there a solution?
Joey....
geposted Mon 16 Nov 09 @ 11:00 pm
You've been given the solution; the search bug is reportedly fixed with v6.0.3. If you're suffering with this problem, you need to upgrade.
List of fixes here:
https://virtualdj.com/wiki/VirtualDJv6.0.3.html
List of fixes here:
geposted Tue 17 Nov 09 @ 5:21 am
