Hey everyone whats up? I'm looking to buy a PA system and honestly I'm feeling a little overwhelmed with the amount of speakers and amps on the market. I just received an offer to play a venue of around 300 people for a Frat social in my town. The area is indoors (in a barn) and is about the size of a high-school gym. I would like to keep my budget at or around $500 if possible but would be willing to spend more. I do realize though that in this industry you get what you pay for and as far as having a good PA goes I feel it is a top priority. Mobility is also an issue. Im Far from an expert on this topic and would greatly appreciate any advice the DJ community could offer me. Thanks guys! peace!
geposted Sun 07 Mar 10 @ 7:12 pm
geposted Sun 07 Mar 10 @ 7:21 pm
To dj a party for 300 people.. 500 bucks is nothing. If you cant afford much, just rent a system... You need 2 speakers and two bass bottoms. You can buy 2 good powered 15 inch speakers for 799 and then you need two bass bottoms. For bass bottoms, i recomend anything that can push 600watts or more in " RMS ". If your going to buy something soon, Your new budget is now 1800 bucks plus....
geposted Sun 07 Mar 10 @ 7:25 pm
Oops I ment to say between $500-$1k, again i realize this might not be enough, I think I want to stay away from powered speakers if possible also.
geposted Sun 07 Mar 10 @ 7:29 pm
geposted Sun 07 Mar 10 @ 7:33 pm
If you want to stay away from Powered speakers.. Buy from the carvin website.. They sell very good speakers tops. They bass bottoms are nice but.. Its kind of dumb to have a bass bottoms impedance @ 8 ohms.. The price is great but i would call them up and ask them if they can switch the woofer to a 4 ohms. An amp pushing alot of watts in 8ohms will cost you more than an amp with higher watts in 4ohms.
geposted Sun 07 Mar 10 @ 7:40 pm
This may help you with your budget:
http://cgi.ebay.com/PAIR-15-3000-Watt-DJ-LOUDSPEAKER-SUBWOOFER-AMPLIFIED_W0QQitemZ250588403914QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a583b98ca
I own a pair of these:
http://cgi.ebay.com/New-Pro-Audio-PA-DJ-1800W-Powered-Speaker-Pair-PP1502A_W0QQitemZ330403254520QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4ced9190f8
and for the price they sound great!! you will not be dissapointed.
The subs:
http://cgi.ebay.com/New-Pair-18-Pro-DJ-Stage-Concert-Sub-Speakers-PPSUB18_W0QQitemZ250590699178QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a585e9eaa
for the price they looks good, I will buy these subs to complete my system (I have thight budget too)
santosac46
The subs:
santosac46
geposted Sun 07 Mar 10 @ 9:48 pm
Powered sub:
http://www.123dj.com/speakers/hifi/bass1501.html
hoe this help.
santosac46
hoe this help.
santosac46
geposted Sun 07 Mar 10 @ 9:52 pm
Your best bet is to rent speakers first and then save money to buy something good. Your going to end up buying something that sucks and you wont be able to sell it for something better.
geposted Sun 07 Mar 10 @ 10:22 pm
@ caliente123
I have 2 amps, one is 500 watts per channel at 8 Ohms, the other is 1500 per channel at 8 Ohms. Thank you for the advise, you always help others.
santosac46
santosac46
geposted Sun 07 Mar 10 @ 10:30 pm
+1 on the rentals. This way you can test different speakers out to see what you will like/need. Saves you $ in the long run as opposed to buying something and not having it work out.
geposted Sun 07 Mar 10 @ 11:19 pm
I'm a big fan of the FBT Maxx4a's but they're priced higher than your budget and they are powered. That being said I would avoid the cheaper speakers. If you're serious about DJing and are in it for the long run then spend a bit more. The higher priced speakers will last longer, sound better and won't overheat and shut down on you.
geposted Sun 07 Mar 10 @ 11:29 pm
This is my current system. I have 2 Carvin PM 15 speaker tops that push 400 watts RMs and 2 JBL MPro 418s Subwoofers that push 600 watts RMS, 2400 watts peak.. For my top speakers, i am using a QSC plx 2402 amp. For the subwwofers, I am using a PLX 3002. Since my subs Impedance is 4 OHms. My amp pushes 900 watts RMs. My system kicks.
One great thing about my Carvin speakers is.. If the tweeters blow, i can use any 1-3/8” x 18 TPI screw on. Im using Pyramid tweeters. Believe it or not, Pyramid makes very good tweeters for a cheap price. 20 bucks just to replace them.
geposted Mon 08 Mar 10 @ 12:04 am
Hey guys thanks for all the feedback you all rock! Caliente thanks for the info regarding the difference between 8 and 4 ohms subs, i hadn't really considered that (and nice specs man wow!). Ive got until April 16th before the gig so I'm going to explore every option. The websites you all suggested seemed really legit as well. Also I'm going to Guitar Center this weekend to see what they can offer me. As far as renting goes I don't think there are a lot of options in my area but I will do some research on that as well. I'm Super excited about all this though, It will be my first time playing a venue of this size and hopefully will mark my transition out of the house party scene. lol been a rough couple months, and wow if I only was getting paid for every time a girl asked me to play Ke$ha =D. Anyways being a new DJ in my area I don't have a lot of contacts yet so I really appreciate being a part of an online DJ Community! Thanks again
-L
-L
geposted Mon 08 Mar 10 @ 2:24 am
With that sort of money you only have one option, - ebay
geposted Mon 08 Mar 10 @ 5:45 am
i would also suggest http://www.americanmusical.com/...here you can pick out your selection.. and if at x amount of dollars you can pay off in 3 or 5 monthly paymnts and still have your equipemnt of choice at your gig...ive done it several times...
geposted Mon 08 Mar 10 @ 8:17 am
So I've been looking at AMS because of their payment plan option. What do you guys think about this system http://www.americanmusical.com/Item--i-AMS-TRANSPORT-LIST
This one seems a good system to start with also
http://www.americanmusical.com/Item--i-AMS-PA1-LIST
geposted Mon 08 Mar 10 @ 7:53 pm
Those speakerts are no good. You will blow them easy. They push 125 watts RMS
geposted Mon 08 Mar 10 @ 7:58 pm
I AM USING 1000 WATT AMP MARATHON JUST BOUGHT SOME 1200 WATT PEAK SPEAKERS SHOULD I GET A NEW AMP AND HOW MUCH WATTAGE
geposted Mon 08 Mar 10 @ 9:08 pm
WHICH AMP SHOULD I GET PYLE PRO MARATHON OR PYRAMID I NEED HELP WITH THIS
geposted Mon 08 Mar 10 @ 9:11 pm
