Forum: Addons
Topic: V8 but by FRUiT - Page: 6
silantatech wrote :
Something that would be awesome for the 4 deck skin would be separate colors for decks 3 and 4. I sometimes get confused when i am in a set and play the wrong deck luke 1 instead of 3 and 2 instead of 4.
Yes :-)
I admit the behavior can be hard to learn. My advice would be : don't think 'deck 1,2,3,4' but rather 'main-sub decks'.
The master deck (blue or red) leads every buttons, while the slave deck (white) is just there to monitor (with basic controls).
Hi FRUiT, Any news on when your next skin update will be and what you have or plan to include?
I don't know... I don't have much time in my life but it keeps growing :)
The plan, must be kept secret that's why I don't post any sreenshots :)
Hey Fruit, hope you're well.
I think that I did see a screenshot somewhere, 'cos I couldn't replicate it with vers6 .... but it looked very interesting!
keep up the good work and I'm looking forward to seeing the next generation of your masterpiece
best regards
ray
Mmm can you point me to where this screenshot is ? Mostly it should be already implemented.
Read the third post of this page.
You may access the sidelist view in the same manner than the recording/broadcast page :)
Latest beta breaks some of your variables.... VU meter no longer shows levels at the sides in scratch mode
true, it's been already addressed (will be out with 0.7). Sorry for this.
Hi, i used your Skin now seven days successive ... 2-deck and 4-deck Modus ... what should i say .... i LOVE it :-)
Thank you very much.
Greets Lokke
You're very welcome :) every feedback is much apreciated :)
after update and no drop down for cue,effects and no LED's meter on sides there is white on deck 2 now.
+1
Same thing for me
Hi when i try to change the view off the browser
``Display list as Choose between the List View (default) and Grid View, with large icons (for Touchscreens)
is missing??? can you help?
Hey, would it be possible to add a "stopwatch" in order to see how Long the set is. It could be good if you will record a mix ;-)
Regards, Thomas
There's a stopwatch already. Click on the time near the cpu meter to cycle between several infos, including a stopwatch.
If you cycle again through the values, the counter will reset.
In the bottom-left corner of the screen you might find a round button (above font size buttons) bringing you into a menu where you can choose several things, including the 'tiles/grid' view and the 'list' view.
That white you see on the deck it occurs on only with songs that has a hot CUE markers. I just experience it and now it is back to normal.
The fix is: See under the crossfader, Decksettings, schroll down to Wheel and "uncheck" songpos.
Practice using Fruit's skin.
15%
