Disponile nuova build 3203 Virtualdj 8.2 attivando
l'opzione EARLY ACCESS dalle configurazioni avanzate
per chi volesse testarla prima del Rilascio Ufficiale
http://it.virtualdj.com/forums/210031/General_Discussion/_NEW__VirtualDJ_8_2.html
geposted Mon 06 Jun 16 @ 12:52 pm
Ecco le novità disponibili su VirtualDJ 8.2 (b3203):
Download ultima versione 8.1 (b2857) stabile -> http://it.virtualdj.com/download/index.html
Download manuale della versione desiderata -> https://virtualdj.com/download/build.html
Changelog -> https://virtualdj.com/products/virtualdj/changelog.html
Per poter scaricare le future 8.2 BETA prima degli altri dovete andare nei settings di VirtualDJ 8.1 -> Opzioni -> Mostra opzioni avanzate e abilitare l'opzione "EarlyAccessUpdates".
Attenzione perchè vi ritroverete con l'ultima versione BETA, se invece volete che VirtuallDJ vi venga aggiornato solo con versioni stabili vi basterà tenere attiva solo l'opzione "checkUpdates".
Lista completa novità prima versione 8.2 (b3203) https://virtualdj.com/wiki/VirtualDJv8.2.html
Quote :
Atomix Productions is proud to announce a new version of its flagship software VirtualDJ, which brings many important improvements and new features:
In an era where DJ hardware is moving more and more toward a better synergy with DJ software, we redesigned VirtualDJ to be more controller-centric.
As such, the new pad section will fit right at home on most modern controllers, but at the same time brings a versatility and easiness that is the trademark of VirtualDJ.
The audio engine has been improved, and we managed to perfect even more our already top-of-the-line BPM analysis algorithm.
And our acclaimed video engine also saw some significant performance boost with a smarter use of hardware acceleration.
The connected aspect has not been forgotten, with some brand new features like Ask.The.DJ
And of course, the overall stability has been maintained to rock-solid level, with the lowest crash ratio in the industry.
Quote :
-New skin with customizable PAD pages http://it.virtualdj.com/plugins/index.html?category=new
-New BPM detection engine
-New BeatGrid detection engine
-New windowing engine, getting look and feel closer together on windows and mac
-Improved action editor with colors and highlighting of if-then-else parts
-Improved touch screen support
-Tag Editor keyboard shortcuts: ALT+LEFT/RIGHT, ALT+SPACE, ALT+ENTER, ALT+W
-Hardware Accelerated video recording (mp4, windows and nvidia only)
-Hardware Accelerated video playback on mac
-Link video to audio file and play linked video without interrupting audio track
-Improved video decoding for sampler and slideshow
-Smarter usage of hardware acceleration for video scratching and looping
-Improved support for WASAPI Exclusive mode
-Improved tag reading: WMA composer tag, MP4 key tag, ID3v2.2 cover art, loop/key info for acid wav
-VST Instrument support: Right-click on midi device (keyboard) in controller options to pass it to VST of a specific deck
-Support for transparent video samples (HAP format)
-Record samples directly to Recordings Bank using 'sampler_rec x' (x is slot number)
-Fix changing existing vdjsample files
-Colored cue points
-Allow silence between mixes in automix by using negative automix fade length
-mix_selected action to mix to selected song in automix
-Fix cracks in automix dualdeck mode
-Karaoke on-screen singer display options
-Export browser view to CSV or HTML
-Ask the DJ: gather audience requests from within the browser (through vdj webpage or twitter)
-browser_zoom support for skins, and implemented in default 2-deck skin
-New audio effect 'Noise'
-More skin options for cue/beatgrid on scratch wave
-Improve quality, memory use and performance of images in video edits
-Improved loopback recording quality
-Colored cue points
geposted Mon 06 Jun 16 @ 1:05 pm
mmm...
vanno fatti rianalizzare il files?
mmm...
geposted Tue 07 Jun 16 @ 7:05 pm
Lo puoi fare tu o farlo fare a vdj quando carica la traccia sul deck cioè vdj rianilizzera le tracce nuovamente non appena caricate
geposted Tue 07 Jun 16 @ 7:58 pm
Non devi fare un tubo, le rianalizza lui se necessario quando le carichi.
Consiglio ai meno esperti e paranoici di non aggiornare per il momento, aspettate che la nuova versione sia stabile ;)
geposted Wed 08 Jun 16 @ 6:57 am
lo sto testando su computers datati, in videoMix, anche se con tutte le precauzioni,
e non mi sembra affatto inaffidabile.
Nel nuovo BpmEngine non ho ancora notato delle sostanziali differenze dal vecchio gia' buono
ma arriveranno anche le tracce strane.
Francamente, piu' che un nuovo motore di analisi, avrei preferito una riedizione del BPMedit
che e' abbastanza ostico da usare per sistemare le griglie sui brani di vecchie generazioni
ma ho aprezzato i tanti nuovi comandi VdjScript
grazie ai quali, prima o poi, ci faro' uno skin dedicato apposta alla sisitemazione delle battute selvagge
e me lo sistemero' in manier4a piu' pratica da utilizzare (come Serato ci ha insegnato).
Augh !
Augh !
geposted Wed 08 Jun 16 @ 7:41 am
Virtualdj 8.2 non ha nessun problema di stabilità ...anzi direi proprio che è molto stabile!
geposted Wed 08 Jun 16 @ 7:42 am
è quasi una 8.5
geposted Wed 08 Jun 16 @ 12:13 pm
Virtualdj 8.2 (b3217) change log
-Il Picker (tabella/raccoglitore) dei colori si può aprire con tasto destro del mouse inserire codice hex
-Su Mac il dock rimane nascosto in modalità schermo intero
-Corretto testo multi linee centrato nelle finestre di dialogo su Mac
-Corretta opzione minimizza su Mac
-Corretto potenziale crash con lo script cue_name
-Corretto potenziale crash nella finestra di login
-Corretta modalità Automix dualdeck dove la lunghezza del mix viene impostata a 0s
-La voce key appare con menù a discesa ordinato nelle configurazioni dei controller e mostrano le key mappate in grassetto
-Corretto calcolo larghezza minima per alcune pagine di configurazione
-Corretta selezione automatica dell'input dalla definizione della scheda audio per la modalità WASAPI
-Corretto script holding
geposted Wed 08 Jun 16 @ 7:07 pm
Non so se ci avete fatto caso ma qui http://it.virtualdj.com/plugins/index.html?category=new
trovate nuovi pacchetti tipo KeyModPlay, BeatGridSL, HotCuesNLoops per personalizzare le modalità dei PAD nelle nuove skin, una volta installati li potrete selezionare direttamente nella skin:
Queste nuove modalità per i PAD possono poi anche essere cancellate o editate
geposted Fri 10 Jun 16 @ 9:53 am
manca solo la modalita' DMX
(io li ho mappati anche per quello, ma sui pads della console, non sullo skin)
Augh !
Augh !
geposted Fri 10 Jun 16 @ 10:46 am
Virtualdj 8.2 (b3236) change log
-Corretto cancellazione key nella configurazione dei controller
-Corretto copia/sposta cartella non ricordava l'ultima cartella in Windows
-Corretto shift/ctrl scambiato per sposta/copia sampler nella cartella sample
-Corretto load tracce dalla lista cloud
-Corretto Ask The Dj alla riapertura cancellava le ricerche
-Corretto crash con Ask The Dj quando non c'è connessione internet
-Corretto lista ask the dj non visualizzata quando la voce 'Mostra file audio' è disattivata
-Corretto problema dell'editor Automix durante la selezione
-Le azioni cue_stop, cue_play e hot_cue possono annullare un backspin in corso
-Corretto scoppiettio audio in modalità esclusiva WASAPI
-Corretto mancanza audio su NetSearch Video
-Corretto risultati video su NetSearch non presenti quando la voce 'Forza NetSearch Video' è attiva e nessun risultato audio CU è presente
-I sampler usano anche lo ZerodB da aggiungere a headroom
-Corretto messaggio di sicurezza al carico di una traccia premendo il tasto canc della tastiera non funzionava
-Corretto crash ASIO quando si mixa tracce con samplerate diversi
-Corretta scheda audio ASIO non rilevata correttamente per utenti con licenza plus
-Aggiunta opzione samplerHeadphones
-Corretto problema casella di controllo karaoke nel tag editor non si poteva selezionare
-Varie correzioni per le mappature da tastiera
geposted Tue 14 Jun 16 @ 7:00 am
Virtualdj 8.2 (b3268) change log
-Miglioramenti a ask.the.dj (geolocalizzazione, luoghi, risposte, ecc)
-Migliorata tabella colorpicker (con più modalità nelle opzioni)
-Varie correzioni alle scorciatoie da tastiera
-I file audio con cover GIF venivano riconosciuti come file video
-Corretto crash su Mac con playlist_save
-Corretto alt-tab con videoForceFullScreen
-Corretto problema con l'azione holding usando lo stesso tasto su deck (lettori) differenti
-Corretto blocco durante l'apertura del sampler editor
-Corretto lettura doppio carattere unicode tag senza marcatore BOM dai tag ID3
-Corretto seleziona cartella nello slideshow
-Corretto selezione dei font su Mac
-Corretto copia cartella su Mac
-Corretto crash quando si cerca di modificare un file vdjedit non più esistente o danneggiato
-Corretto messaggio popup lista effetti per visualizza solo audio
-Corretto blocco potenziale nella configurazione del timecode
geposted Mon 20 Jun 16 @ 11:05 pm
Virtualdj 8.2 (b3272) change log
-Minimizzando VDJ non viene nascosta/chiusa la finestra video
geposted Tue 21 Jun 16 @ 3:57 pm
Virtualdj 8.2 (b3278) change log
-Il plugin beatgrid ha anche l'opzione di video
-Corretto potenziali crash con skin con finestre multiple
-Corretto potenziale blocco con il pulsante di registrazione
-I plugins con setup grafico sono compatibili con dpi alti
geposted Fri 24 Jun 16 @ 12:48 pm
Virtualdj 8.2 (b3286) change log
-Corretto Ask The Dj come scorciatoia nel pannello sideview
-Corretto Enumerazione dei caratteri su Windows
-Corretto crash riaprendo gli effetti su Mac
-Corretto dimensione interfaccia plugin non personalizzati su schermi con DPI alti
geposted Mon 27 Jun 16 @ 7:08 am
nuovo aggiornamento early access
-Corretto problema di aggancio nella finestra cover
-Aggiunto supporto per connetti/disconnetti su Mac per drive removibili
-Corretta visualizzazione persa aprendo la finestra di immissione del testo sui touch
geposted Wed 13 Jul 16 @ 7:08 am
Disponibile nuova build Early Access 3324
Changelog :
-Corretto slideshow su Mac
-Corretto arresto dell'audio per i possessori di licenza PLUS (per i controller che condividono i driver ASIO con altri controller)
-Corretto crash sui pad
-E' Possibile spostare verso l'alto la posizione dei brani in riproduzioneo per garantire che tutta la lista venga riprodotta
-Vengono mostrati tutti i canali disponibili su Mac
-Aggiunta modalità hotcue al menù della pagina KeyCue
-Aggiunto spunta comando hardwareShift sui controller per quelli che inviano lo shift, ma usano lo shift sul hardware
-Corretto drag& per la perdita di file multipli nel finder su Mac
-Corretta visualizzazione tempo in millisecondi sui lettori cdj2000nxs2
-Corretta opzione mix_and_load_next
-L'opzione mix_now non sincronizza i bpm se la differenza è superiore al 10%
-Migliorata selezione ingressi di linea per i deck (lettori) 3 e 4
-Corretto possibile perdita di mapper personalizzato passando tra mapper dello stesso controller
-Aggiunta pagina pad keycue
Changelog :
geposted Tue 19 Jul 16 @ 4:35 pm
Nuove build Early Access 3342 e 3343
Change log 3342 :
-I raiting dei tag ID3 sono compatibili con quelli di Windows explorer/media player
-Implementata GUI degli effetti VST su Mac
-Corretto blocco all'avvio con errore skin su Mac
-Corretto risultato del testo usando l'azione get_time con il parametro unità
-Corretto tempo di fade del effetto slideshow non memorizzato
-Corretto azione loop_pad_mode x query
-Aggiunta opzione 'fxProcessing' per selezionare gli effetti pre o post fader
-Migliorate le prestazioni del plug-in camera e la selezione automatica della risoluzione
-Corretto ottenere offuscamento colori con l'azione color
-Corretto spostare i file nella lista, mentre Automix sta rimuovendo i file riprodotti
Change log 3343 :
-Corretto registrazione video
Change log 3342 :
Change log 3343 :
geposted Mon 01 Aug 16 @ 11:26 am
Nuova build early access 3378 change log
-L'effetto Boom Auto basa il parametro velocità in base alle battute
-Aggiunte le azioni pioneer play_led e pioneer_cue_led
-Corretto lettura cdg Karaoke con sync non corretti
-Aggiunto il supporto per la trasmissione UPNP
-Aggiunto supporto per Quartz Compositions tra gli effetti video su Mac
-Aggiunta nuova opzione RPM a 4 battute da usare per le tracce con BPM variabile
-Corretto crash del plugin camera su Mac
-Corretto azioni get_time_min ecc quando usate nei campi di testo
-Corretto finestre delle skin a multi-finestra non mostravano il load delle tracce
-Corretto il sampler (campionatore) non visualizzava il testo o l'immagine di alcuni formati
-Corretto il download delle cover
-Piccolla correzione dell'editor tracce
-Nuova azione "Add Lyrics" nel Video Editor
-Corretto dati parsing con zeri primari
-Corretto spostamento di una cartella
-Corretto crash con virtualfolder_add
-Corretto crash dei pad con controller midi generici
geposted Mon 22 Aug 16 @ 11:57 am
